oranda
Aug 23, 2012Aspirant
RND4000 NV+ v2 & Seagate 3TB drives - firmware issue on iMac
I have 2 new Netgear recommended , Seagate 3TB Barracuda Hard Drives which on the Netgear compatability page says may require a firmware upgrade. On the Seagate site it states that the CC4H upgrade...
Aug 23, 2012Guru - Experienced User
There is this general warning here: http://forums.seagate.com/t5/Barracuda-XT-Barracuda-Barracuda/Frequently-Asked-Questions-related-to-firmware-issues/td-p/23154
oranda wrote: The warning regarding not using CC4H for RAID drives appears when running the windows installation software...
Q: Can I update the firmware while my drive is connected to a RAID controller?
A: Customers utilizing RAID architectures incorporating affected products should back up all data content before upgrading drives with the firmware solution. For some arrays firmware upgrades may cause RAID management software to require the array to be rebuilt. Please consult the technical documentation and procedure recommended by the RAID controller manufacturer for your system prior to upgrading any affected product in an array. Please proceed with caution and contact Seagate Technical Support for assistance.
That wouldn't apply to your situation, since these drives aren't even formatted.
That'd be much easier than doing trying to do it on the iMac.
oranda wrote: I may have to take the drives into work (I'm on holiday at the moment, and get my IT guys to do the upgrade for me)
dts002
Aug 19, 2015Aspirant
I am using this Netgear NAS with Western Digital and not Seagate hard drives.
These Western Digital hard drives are listed below (as well as in the attached screenshot).
Is there a special Western Digital firmware update that I should load?
Or if I can load the Seagate firmware update (from the http://knowledge.seagate.com/articles/en_US/FAQ/223651en website) then which one do I load? I want to be sure to load the right one (see the screenshot).
Channel 1 WDC WD30EFRX-68EUZN0 [ 746 GB ] 761916 MB
Channel 2 WDC WD30EFRX-68EUZN0 [ 746 GB ] 761916 MB
Channel 3 WDC WD30EFRX-68EUZN0 [ 746 GB ] 761916 MB
Channel 4 WDC WD30EFRX-68EUZN0 [ 746 GB ]
- StephenBAug 19, 2015Guru - Experienced User
You have an NV+ V1 (and yes the labels are confusing...). Read this: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Your NAS is limited to 2 TB drives, it does not support anything larger.
- dts002Aug 19, 2015Aspirant
OK so is there any way that we can make this NAS recognize these four 3 TB hard drives as 2 TB hard drives?
If so how can this be done?
Please provide me with the exact steps.
