oranda
Aug 23, 2012Aspirant
RND4000 NV+ v2 & Seagate 3TB drives - firmware issue on iMac
I have 2 new Netgear recommended , Seagate 3TB Barracuda Hard Drives which on the Netgear compatability page says may require a firmware upgrade. On the Seagate site it states that the CC4H upgrade...
dts002
Aug 19, 2015Aspirant
I am using this Netgear NAS with Western Digital and not Seagate hard drives.
These Western Digital hard drives are listed below (as well as in the attached screenshot).
Is there a special Western Digital firmware update that I should load?
Or if I can load the Seagate firmware update (from the http://knowledge.seagate.com/articles/en_US/FAQ/223651en website) then which one do I load? I want to be sure to load the right one (see the screenshot).
Channel 1 WDC WD30EFRX-68EUZN0 [ 746 GB ] 761916 MB
Channel 2 WDC WD30EFRX-68EUZN0 [ 746 GB ] 761916 MB
Channel 3 WDC WD30EFRX-68EUZN0 [ 746 GB ] 761916 MB
Channel 4 WDC WD30EFRX-68EUZN0 [ 746 GB ]
Aug 19, 2015Guru - Experienced User
You have an NV+ V1 (and yes the labels are confusing...). Read this: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Your NAS is limited to 2 TB drives, it does not support anything larger.
- dts002Aug 19, 2015Aspirant
OK so is there any way that we can make this NAS recognize these four 3 TB hard drives as 2 TB hard drives?
If so how can this be done?
Please provide me with the exact steps.
