mbehm
May 14, 2018Aspirant
RND4000 (ReadyNAS NV+ no longer visible from Network wirelessly after 5 years - frontend works fine
seemingly out of the blue both my windows7 and windows10 laptops can no longer access my readyNas VN+. I've tried rebooting laptops... NAS, and modem... turned off everything in the network and back...
- May 23, 2018
It would be a good time to make a backup.
mbehm
May 15, 2018Aspirant
Ok.. I checked the SMB and it was not active... I activated and restarted... same symptoms... forgot to mention that I can see other computers on the network... only the NAS is not visible
mbehm
May 17, 2018Aspirant
That didn't work on either my windows7 or windows10 machine... both saw 'Windows cannont access \\192.168.1.76
error code 0x80004005 and 'diagnose' found not errors... surprise surprise
- StephenBMay 17, 2018Guru - Experienced User
Try rebooting the PC, and then opening CMD (command prompt). Enter
net use * /delete
net use t: \\192.168.1.76\C /user:admin nas-admin-password
using the real admin password of course. Be careful on both spaces and the slash directions.
The first command terminates any open network sessions to the NAS (likely there won't be any). The second attempts to mount the NAS C volume as drive letter t.
- mbehmMay 17, 2018Aspirant
On my windows10 machine i got this
C:\Users\Mikw Bwhm>net use t: \\192.168.1.76\C /user:admin <I used correct pw>
System error 384 has occurred.
You can't connect to the file share because it's not secure. This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack.
Your system requires SMB2 or higher. For more info on resolving this issue, see: https://go.microsoft.com/fwlink/?linkid=852747On windows7 machine
I got
System error 58 has occurred
The specified server cannot perform the requested operation
That message suggests that the SMB 1.0 client is not installed on the Windows 10 system. Is that correct?
