mbehm
May 14, 2018Aspirant
RND4000 (ReadyNAS NV+ no longer visible from Network wirelessly after 5 years - frontend works fine
seemingly out of the blue both my windows7 and windows10 laptops can no longer access my readyNas VN+. I've tried rebooting laptops... NAS, and modem... turned off everything in the network and back...
- May 22, 2018
It would be a good time to make a backup.
mbehm
May 17, 2018Aspirant
On my windows10 machine i got this
C:\Users\Mikw Bwhm>net use t: \\192.168.1.76\C /user:admin <I used correct pw>
System error 384 has occurred.
You can't connect to the file share because it's not secure. This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack.
Your system requires SMB2 or higher. For more info on resolving this issue, see: https://go.microsoft.com/fwlink/?linkid=852747
On windows7 machine
I got
System error 58 has occurred
The specified server cannot perform the requested operation
May 17, 2018Guru - Experienced User
That message suggests that the SMB 1.0 client is not installed on the Windows 10 system. Is that correct?
- mbehmMay 17, 2018Aspirant
corrent. I enabled it and tried again... this time I get the following from the net use command
System error 53 has occurred.
The network path was not found.I can ping 192.168.1.76 from both the windows 10 and 7 machines
- StephenBMay 18, 2018Guru - Experienced User
Is there any internet security software running on the PCs? If there is, try disabling it and retesting.
Can you try downloading the logs from RAIDar, and take a look at disk_usage.log. look at the first entry (something like what's below)
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 2.0G 444M 1.6G 23% /Do you have a similar amount of free space?
- mbehmMay 21, 2018Aspirant
What I see in the logs is
Mon May 21 11:22:46 CDT 2018 Volume is approaching capacity: 100% used 1.2M available
