mbehm
May 14, 2018Aspirant
RND4000 (ReadyNAS NV+ no longer visible from Network wirelessly after 5 years - frontend works fine
seemingly out of the blue both my windows7 and windows10 laptops can no longer access my readyNas VN+. I've tried rebooting laptops... NAS, and modem... turned off everything in the network and back...
- May 22, 2018
It would be a good time to make a backup.
mbehm
May 22, 2018Aspirant
I think I've resolved the issue... I reloaded the OS and it's now working
May 22, 2018Guru - Experienced User
- mbehmMay 23, 2018Aspirant
This is a backup of a backup... thanks for all the prompt replies...
- StephenBMay 23, 2018Guru - Experienced User
Good to know. This could be related to OS partition fullness, and if that's the case the problem will recur.
I suggest clearing the logs from the web ui, and then after that downloading fresh ones. Then look in disk_usage.log at the OS partition fullness as shown here: https://community.netgear.com/t5/Using-your-ReadyNAS/RND4000-ReadyNAS-NV-no-longer-visible-from-Network-wirelessly/m-p/1572728#M145776 If the OS partition still looks very full, then I'd recommend a factory reset, and reload the files from the source.
Also, your data volume is extremely full, so if you are continuing to write files to it, you should probably delete some of the content.
