tjandra
Jun 30, 2017Follower
RND4000 (ReadyNAS NV+ v1) - add more disk to get more than 2 volumes?
I inherited this device, which has 2x300GB disks, and set up as 2 volumes (one for each disk). In the Volume Settings it says "RAID Level 0, single disk) on each volume. The volumes are almost out of...
- Jul 01, 2017
If you have two volumes, that means you're in Flex-RAID mode. So if you insert a new HDD, it won't be automatically added to an existing volume.
Insert the new HDD and you will be able to create a third volume.
You can also check the compatibility list: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
