MarkinMacon
Jun 27, 2020Aspirant
RND4000 (ReadyNAS NV+) V1 booting forever - semi-responsive
There is a simple question at the end but first a little background. RND4000 (ReadyNas NV+) V1 Connected to Windows 10 64 1909 16 GB on PC Firmware 4.1.16 RAIDar 4.3.8 Firefox browser 77.01 ...
- Jun 28, 2020
I do suggest getting a UPS when you get the system up and running again.
MarkinMacon wrote:
>>> My question is: what is the Tech Support userid and password? I assume all responsibility for whatever I do because I am at the end of my options with a factory reset looking like the only other option. Any help would be much appreciated. Thank you.
The username is root, the password is infr8ntdebug
Once in, the steps depend a bit on whether you are running XRAID or FlexRAID.
Begin with
# start_raid.sh
Then mount the OS partition. If you are using XRAID, enter
# mount /dev/hdc1 /sysroot
if you are running flexraid, enter
# mount /dev/md0 /sysroot
You will want to chroot, so you can run the full set of linux commands
# mount --bind /proc /sysroot/proc # mount --bind /dev /sysroot/dev # mount --bind /dev/pts /sysroot/dev/pts # mount --bind /sys /sysroot/sys # chroot /sysroot /bin/bash
Assuming the data volume is ok, you would then mount it with
# vgscan # vgchange -a y # mount /dev/c/c /c
Though perhaps it would be better to mount it read only:
# mount -o ro /dev/c/c /c
If you don't have a backup, then it would be wise to begin by making one (mounting a USB drive, or starting up samba). You then have the option of doing a factory default, and restoring the files from backup.
I'm not sure about OS 4.1.x, but I think you can trigger OS reinstall or a factory default from ssh. Make sure the OS partition isn't too full before you try the OS reinstall (normally it is about 25% full).
OS re-install:
# touch /.os_update
then reboot.
Factory default:# touch /.os_install
then reboot.
MarkinMacon
Jun 29, 2020Aspirant
Awesome response, StephanB!! Thank you for taking the time to document all of the commands needed. I followed your instructions and was able to see all of my files. My task now is to mount a USB drive and offload everything before using the touch command you noted to trigger an OS reinstall. Since I made the original post, I removed all of the drives, inserted my spare drive into slot 1 and hit the power button. Flawless execution - requested an IP address, installed OS, prepared the C: volume, then waited for data. That tells me that the problem lies in the OS on my regular four-drive array. I did make one deviation from your instructions; the "mount --bind /sys /sysroot/sys" failed due to /sys not being found. I initially thought that the absence of /sys was the source of my problem. I checked several Internet websites that discuss the Linux OS file structure and did not see /sys mentioned. So, I forged on with the CHROOT command and had no problems at all from that point. Your help was invaluable and again, I thank you very much.
MarkinMacon
Jun 30, 2020Aspirant
I have additional information to flesh out this entry. Thanks to StephenB, I was able to telnet to Tech Support mode and issue Linux commands (most but not all are available). As I prepared to offload data to a USB drive, I connected the drive (2 TB drive in a dock) then logged on to the box. When I issued a "fdisk -l" command, it listed four drives when I expected five. I closely examined the four drives and confirmed that they were the four 2 TB drives in the NV+. I forgot about wondering where the USB drive was when I saw that drive 2 showed a message that said "does not contain a valid partition table". That couldn't be good. But that made me recall that when I booted in "bypass vol check" mode, it did indicate that it was "syncing drive 2" but otherwise there was no indication of a problem. So, what to do? I shutdown the box, then pulled drive 2 to simulate a drive failure and rebooted normally. It came all the way up such that RAIDar could talk to it, Frontview could talk to it and I could map the shares and read the data. ALL WAS GOOD!! Since the drives are hot-swappable, I then inserted my spare 2 TB drive into slot 2. It detected it and indicated that a resynch of drive 2 was in progress, 0% complete, 3 minutes remaining. After an hour that had not changed regardless of how much the ACT LED blinked. I shut it down, pulled drive 2 and rebooted again. I am now offloading data that I want to save via ethernet and although it is slow it is solid. I'll deal with drive 2 later.
