tupholme
Oct 05, 2018Aspirant
RND4000 volume scan/RAID sync every day
Hi,
I have the ReadyNAS NV+ RND4000, up to date with the latest firmware. It's been running flawlessly for about ten years albeit with only light use. It powers down overnight and there are man...
Oct 05, 2018Guru - Experienced User
Have you looked in the log zip file for more details on the volume scans?
- tupholmeOct 06, 2018Aspirant
Thanks, I'd overlooked that option. This is what I'm getting repeated in fs_check.log:
***** File system check performed at Thu Oct 4 17:41:50 GMT 2018 ***** fsck 1.40.11 (17-June-2008) e2fsck 1.40.11 (17-June-2008) c was not cleanly unmounted, check forced. Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information c: 134393/178307072 files (5.6% non-contiguous), 319068372/356589568 blocks
I note the "c was not cleanly unmounted, check forced." line! I'm slightly reassured that it's not something worse data-wise, but given that I'm not aware of any external reasons why there could be spontaneous outages, e.g., power cuts, it leads me to think that the ReadyNAS is fully rebooting itself. In other words, the volume scan is a symptom not the problem in itself.
If I then look in the system.log I can see this (filtered):
Oct 4 07:11:43 nas-01-B6-06 kernel: Boot type/reason: rtc/0/0 Oct 4 10:43:25 nas-01-B6-06 kernel: Boot type/reason: normal/2/0 Oct 4 19:39:41 nas-01-B6-06 kernel: Boot type/reason: normal/0/0
The first of these events was when it woke up in the morning, the second was when I forced a reboot and the third was spontaneous. Thus we can see there is something non-routine going on, but I'm not sure where to go from here. Frontview always shows reasonable operating temperatures and I haven't had issues with any of my other equipment on the same circuit having crashes etc..
Thanks for any advice offered!
Jeff
- StephenBOct 07, 2018Guru - Experienced User
I guess there could be something going on with the power, but I'm thinking it's more likely to be a failing PSU or maybe a system board component.
Given the age of the NAS, replacing it might be the best option. You could replace the PSU with some effort, but of course we don't really know if that's the cause or not.
- tupholmeOct 07, 2018Aspirant
Yes I was beginning to think that a replacement might be the way to go...
Today I decided that cleaning up the ReadyNAS might help and it turned out to be full of dust. I vacuumed it all out and it looks good. However, now it won't start up! I'm going to try the battery reset procedure, but tomorrow as I don't have time now. Technology, eh?
