CharlesR
Aug 26, 2014Guide
RNDP2000 vs RNDU2000 Performance
Anyone have any real world opinions about their relative performance? Say with streaming one client and perhaps a decent amount of ISCSI activity (say four concurrent recordings)? Trying to decide if ...
xeltros
Aug 30, 2014Apprentice
The first disk inserted determines the smallest disk size on the NAS, so if you insert the 3tb first then you won't be able to use other spare disks with smaller capacity.
X-raid 2 will by default do raid1 when there are two disks, raid5 when there are more. You can disable it and use flex-raid to fine tune your choices if needed. If you want to use flex-raid disable x-raid before inserting the second disk.
I think you can switch from x-raid to flex-raid but I'm not sure the reverse is possible without a factory reset or at least a volume deletion.
