CharlesR
Aug 26, 2014Guide
RNDP2000 vs RNDU2000 Performance
Anyone have any real world opinions about their relative performance? Say with streaming one client and perhaps a decent amount of ISCSI activity (say four concurrent recordings)? Trying to decide if ...
Aug 30, 2014Guru - Experienced User
That's true for an xraid volume, but of course with flexraid you can create a new volume with a smaller disk (without losing the original volume).
xeltros wrote: The first disk inserted determines the smallest disk size on the NAS, so if you insert the 3tb first then you won't be able to use other spare disks with smaller capacity.
You can certainly switch to flexraid. If you have a single volume you can also switch back.
xeltros wrote: I think you can switch from x-raid to flex-raid but I'm not sure the reverse is possible without a factory reset or at least a volume deletion.
