luukee
Jun 27, 2017Aspirant
RNDP200U having network issues
hey guys i'm having this issue with our NAS and not sure what's happening. we have a Model: RNDP200U and it loses network connectivity (no pings) upon manual restart it would work again. it'...
- Jun 28, 2017
luukee wrote:
I coudn't find the OS partitian log, but i found the partition log.
Look at the first device listed in disk_usage.log
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 1.7G 2.2G 44% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 14T 8.7T 5.0T 64% /c...
Mine is rather full BTW, normally is is around 20%
luukee wrote:
Settings for eth1:
Speed: 100Mb/sIs this expected? Most people with x86 NAS are using gigabit networks.
If you are connecting to a gigabit switch or router, then you probably have a bad cable. You could shift it to the other ethernet port, and see if that also negotiates the same speed.
Hopchen
Jun 27, 2017Prodigy
Hi,
Maybe it is network related. Can you download the logs and examine the network_settings.log
Is there a lot of dropped packets or errors on the network interfaces stats?
- luukeeJun 27, 2017Aspirant
Thanks for replying and thank you for the advice, i'll look into it.
hmm. looks like there's 2 network ports, i should the other port?
thanks again for your help guys
network settings:
bond0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Interrupt:16 Memory:fe9dc000-0eth1 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX
inet addr:192.168.x.x Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:83950 errors:0 dropped:7 overruns:0 frame:0
TX packets:83980 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15106850 (14.4 MiB) TX bytes:46824875 (44.6 MiB)
Interrupt:18 Memory:febdc000-0lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:33367 errors:0 dropped:0 overruns:0 frame:0
TX packets:33367 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1905007 (1.8 MiB) TX bytes:1905007 (1.8 MiB)tunl0 Link encap:IPIP Tunnel HWaddr
NOARP MTU:1480 Metric:1
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)IPV6_ASSIGN_eth0=OFF
IPV6_ASSIGN_eth1=OFF
JUMBO_FRAMES_eth0=0
JUMBO_FRAMES_eth1=0
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION
SPEED_DUPLEX_eth1=AUTO_NEGOTIATION
Settings for bond0:
Link detected: no
Settings for eth1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: g
Wake-on: d
Link detected: yes
Settings for eth0:
Advertised link modes: Not reported
Advertised auto-negotiation: No
Speed: Unknown! (65535)
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 0
Supports Wake-on: g
Wake-on: d
Link detected: no
bond0:0:partition log
***** partition output for sda *****
Disk /dev/sda: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 382CB5B8-A4DA-406C-8966-639849CEAB46
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 3907025072 1.8 TiB FD00Disk /dev/sda: 243201 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0Device Boot Start End #cyls #blocks Id System
/dev/sda1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
***** partition output for sdb *****Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 4541E6D7-AA48-4F2D-A43A-D92BC4508639
3 9437248 3907025072 1.8 TiB FD00Disk /dev/sdb: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty- StephenBJun 28, 2017Guru - Experienced User
luukee wrote:
Settings for eth1:
