luukee
Jun 27, 2017Aspirant
RNDP200U having network issues
hey guys i'm having this issue with our NAS and not sure what's happening. we have a Model: RNDP200U and it loses network connectivity (no pings) upon manual restart it would work again. it'...
- Jun 28, 2017
luukee wrote:
I coudn't find the OS partitian log, but i found the partition log.
Look at the first device listed in disk_usage.log
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 1.7G 2.2G 44% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 14T 8.7T 5.0T 64% /c...
Mine is rather full BTW, normally is is around 20%
luukee wrote:
Settings for eth1:
Speed: 100Mb/sIs this expected? Most people with x86 NAS are using gigabit networks.
If you are connecting to a gigabit switch or router, then you probably have a bad cable. You could shift it to the other ethernet port, and see if that also negotiates the same speed.
Hopchen
Jun 27, 2017Prodigy
Hi,
Maybe it is network related. Can you download the logs and examine the network_settings.log
Is there a lot of dropped packets or errors on the network interfaces stats?
