luukee
Jun 27, 2017Aspirant
RNDP200U having network issues
hey guys i'm having this issue with our NAS and not sure what's happening. we have a Model: RNDP200U and it loses network connectivity (no pings) upon manual restart it would work again. it'...
- Jun 28, 2017
luukee wrote:
I coudn't find the OS partitian log, but i found the partition log.
Look at the first device listed in disk_usage.log
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 1.7G 2.2G 44% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 14T 8.7T 5.0T 64% /c...
Mine is rather full BTW, normally is is around 20%
luukee wrote:
Settings for eth1:
Speed: 100Mb/sIs this expected? Most people with x86 NAS are using gigabit networks.
If you are connecting to a gigabit switch or router, then you probably have a bad cable. You could shift it to the other ethernet port, and see if that also negotiates the same speed.
