luukee
Jun 27, 2017Aspirant
RNDP200U having network issues
hey guys i'm having this issue with our NAS and not sure what's happening. we have a Model: RNDP200U and it loses network connectivity (no pings) upon manual restart it would work again. it'...
- Jun 28, 2017
luukee wrote:
I coudn't find the OS partitian log, but i found the partition log.
Look at the first device listed in disk_usage.log
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 1.7G 2.2G 44% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 14T 8.7T 5.0T 64% /c...
Mine is rather full BTW, normally is is around 20%
luukee wrote:
Settings for eth1:
Speed: 100Mb/sIs this expected? Most people with x86 NAS are using gigabit networks.
If you are connecting to a gigabit switch or router, then you probably have a bad cable. You could shift it to the other ethernet port, and see if that also negotiates the same speed.
luukee
hmm. looks like there's 2 network ports, i should the other port?
thanks again for your help guys
network settings:
bond0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Interrupt:16 Memory:fe9dc000-0
eth1 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX
inet addr:192.168.x.x Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:83950 errors:0 dropped:7 overruns:0 frame:0
TX packets:83980 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15106850 (14.4 MiB) TX bytes:46824875 (44.6 MiB)
Interrupt:18 Memory:febdc000-0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:33367 errors:0 dropped:0 overruns:0 frame:0
TX packets:33367 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1905007 (1.8 MiB) TX bytes:1905007 (1.8 MiB)
tunl0 Link encap:IPIP Tunnel HWaddr
NOARP MTU:1480 Metric:1
IPV6_ASSIGN_eth0=OFF
IPV6_ASSIGN_eth1=OFF
JUMBO_FRAMES_eth0=0
JUMBO_FRAMES_eth1=0
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION
SPEED_DUPLEX_eth1=AUTO_NEGOTIATION
Settings for bond0:
Link detected: no
Settings for eth1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: g
Wake-on: d
Link detected: yes
Settings for eth0:
Advertised link modes: Not reported
Advertised auto-negotiation: No
Speed: Unknown! (65535)
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 0
Supports Wake-on: g
Wake-on: d
Link detected: no
bond0:0:
partition log
***** partition output for sda *****
Disk /dev/sda: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 382CB5B8-A4DA-406C-8966-639849CEAB46
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 3907025072 1.8 TiB FD00
Disk /dev/sda: 243201 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sda1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
***** partition output for sdb *****
Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 4541E6D7-AA48-4F2D-A43A-D92BC4508639
Disk /dev/sdb: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
Jun 28, 2017Guru - Experienced User
luukee wrote:
Settings for eth1:
Speed: 100Mb/s
- luukeeJun 29, 2017Aspirant
Thanks stephenb, I'll replace the cable first. I'll check if my router is gigabit as well.
If I plug in a second cable to the second nic, would it conflict if I have both connected?
- StephenBJun 29, 2017Guru - Experienced User
If you don't know what you are doing, yes.
I suggest not connecting both until we sort out your connection issue. You can try moving your cable to the second port.
- luukeeJul 02, 2017Aspirant
thanks StephenB, i connected a new cable to the current NIC port, so not sure how stable it'll be but keeping an eye on it.
the port is currently using a static IP, and all my devices are connecting via that IP. So that's why I was wondering about connecting to the second port at the same time if it would conflict. Great tip though, i won't try it. (If i do, i'll change the first port to DHCP first, then set the second to static).
