vcsnj
Sep 08, 2012Aspirant
RNDP4000 Problem with FTP Directory Listing
Hello everyone, I log in with my FTP client (in this case FileZilla) and everything goes through but it never lists the directory. User name and passwords correct. Port forwarded to RNDP4000 corr...
Sep 08, 2012Guru - Experienced User
Are you also forwarding the passive ports in your router? The NAS is advertising port 60033 in your log "Response: 227 Entering Passive Mode (74,102,103,93,234,129)"
Also, your masquerade address (set in the NAS) is the same as your public IP address (which is the 74.x.x.x. address in your post). For some routers, you need to connect using the local IP address (often 192.168.x.x) when on the local LAN. If your router happens to require that, you need to set the masquerade to the local IP address. With FileZilla, setting the masquerade that way still lets you connect over internet.
