Mindl
Jul 01, 2017Tutor
RNDP6350 won’t start
Every 3 months i do a backup-job and when finished, i shut down my Readynas and cut it from the powersupply. Today my Readynas didn’t start any longer. Absolute no reaction (no fan, no bootmenu, ...
- Jul 18, 2017
From your description, I would have guessed that it is the +5VSB (5 volt standby) power that's the issue. But you say all pins have the right voltages. Still, if you have a stanbdard ATX supply available, you may want to try connecting it externally and see if that fixes the issue.
+5VSB powers the LAN circuit (for WoL) and the turn-on circuit.
Mindl
Jul 03, 2017Tutor
Hello Marty_M,
this was, what i did first; I'll contact the support with a very little hope. I bought the Readynas in 2010.
thanks to all
Marty_M
Jul 03, 2017NETGEAR Employee Retired
Hello Mindl,
You can PM me the serial number of the NAS and I will try to check the warraty status.
Marty_M
NETGEAR Community Team
- MindlJul 10, 2017Tutor
I contacted Netgear Austria (Channel Manager), but until now there is no solution; I'm waiting for an answer.
- MindlJul 14, 2017Tutor
Ultimate advice from Netgear-support was, to buy a new Readynas. Obviously it is a hardware failure and out of the warranty-period they will not repair my device, not even on my own costs.
This is very disappointing andyou have to consider in case of buying a new netgear-device.
Thanks to all for your efforts
Mindl
- mdgm-ntgrJul 15, 2017NETGEAR Employee Retired
There is advice on the community as to how to replace the PSU at your own risk. That sounds like the most likely component to be at fault.
Unfortunately it is not practical for us to do out of warranty hardware repairs.
