Mindl
Jul 01, 2017Tutor
RNDP6350 won’t start
Every 3 months i do a backup-job and when finished, i shut down my Readynas and cut it from the powersupply. Today my Readynas didn’t start any longer. Absolute no reaction (no fan, no bootmenu, ...
- Jul 18, 2017
From your description, I would have guessed that it is the +5VSB (5 volt standby) power that's the issue. But you say all pins have the right voltages. Still, if you have a stanbdard ATX supply available, you may want to try connecting it externally and see if that fixes the issue.
+5VSB powers the LAN circuit (for WoL) and the turn-on circuit.
mdgm-ntgr
Jul 15, 2017NETGEAR Employee Retired
There is advice on the community as to how to replace the PSU at your own risk. That sounds like the most likely component to be at fault.
Unfortunately it is not practical for us to do out of warranty hardware repairs.
Sandshark
Jul 18, 2017Sensei
- MindlJul 21, 2017Tutor
Hello Sandshark
as the PSU of my readynas Pro - a seasonic SS-300SFD - was still available i orded it to follow your advice. Unfortunatly the cable to the mainboard-connector was to short; so i had to do a series of modifications to the chassis (turn the PSU 90° clockwise to reach the mainboard connector, therefore mount the chassis-fan outside, cut a little window in the chassis to reach the new position of the on-off switch and powerplug-cable.
It works and i'm happy
Thank you very much
Mindl
- SandsharkJul 21, 2017Sensei
Too late now, I guess, but if you had searched the forum you would have found that a readily available 6-inch extension for the ATX connector was all you needed to complete an internal installation.
