mrQQ
Sep 03, 2015Apprentice
RNDU4000 loses network
Hello, I've been using RNDU4000 on 6.x os for a long time and it was mostly fine. However, lately, such things started happen: all of sudden, every few weeks or so, I can no longer access the NAS...
mdgm-ntgr
Sep 03, 2015NETGEAR Employee Retired
Which version of OS6 are you running?
JennC
Sep 04, 2015NETGEAR Employee Retired
Hello mrQQ,
Do you have RAIDar installed on the computer?
Please check if it will see the NAS and what IP address it shows.
- mrQQNov 08, 2015Apprentice
Hello,
sorry for very late reply, but I was on vacation, then on business trip..
anyway, now it happened again, and RAIDar is not able to locate it either. Looking at it physically it still shows correct IP address, so it thinks it's fine, but it's not.
- StephenBNov 08, 2015Guru - Experienced User
What firmware are you running? Does your router have IPv6 turned on?
- JennCNov 10, 2015NETGEAR Employee Retired
Hello mrQQ,
What IP address does it show on the display screen?
Have you tried another computer?
- mrQQNov 14, 2015Apprentice
Correct one, the one it's supposed to have.
