tony2001
Oct 30, 2018Aspirant
RNDU4000 Stuck in safe mode
Hello.
Recently my ReadyNAS Ultra 4 hung again (it hangs approx. each week, I reboot it and it works fine for a week after that) and after reboot it started in Safe Mode. There seem to be no wa...
tony2001
A bit of logs (I hope it's relevant).\
Oct 30 06:57:45 nas-26-CB-3C kernel: scsi 6:0:0:0: Direct-Access SMI USB DISK 1100 PQ: 0 ANSI: 0 CCS
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: Attached scsi generic sg4 type 0
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: Embedded Enclosure Device
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: Wrong diagnostic page; asked for 1 got 0
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: Failed to get diagnostic page 0xffffffea
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: Failed to bind enclosure -19
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: [sde] 244736 512-byte logical blocks: (125 MB/120 MiB)
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: [sde] Write Protect is off
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: [sde] Mode Sense: 43 00 00 00
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: [sde] No Caching mode page found
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: [sde] Assuming drive cache: write through
Oct 30 06:57:45 nas-26-CB-3C kernel: random: nonblocking pool is initialized
Oct 30 06:57:45 nas-26-CB-3C kernel: sde: sde1
Oct 30 06:57:45 nas-26-CB-3C kernel: sd 6:0:0:0: [sde] Attached SCSI removable disk
Oct 30 06:57:45 nas-26-CB-3C kernel: md: md0 stopped.
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sdb1>
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sdc1>
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sdd1>
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sda1>
Oct 30 06:57:45 nas-26-CB-3C kernel: md/raid1:md0: active with 4 out of 4 mirrors
Oct 30 06:57:45 nas-26-CB-3C kernel: md0: detected capacity change from 0 to 4290772992
Oct 30 06:57:45 nas-26-CB-3C kernel: md: md1 stopped.
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sdb2>
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sdc2>
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sdd2>
Oct 30 06:57:45 nas-26-CB-3C kernel: md: bind<sda2>
Oct 30 06:57:45 nas-26-CB-3C kernel: md/raid10:md1: active with 4 out of 4 devices
Oct 30 06:57:45 nas-26-CB-3C kernel: md1: detected capacity change from 0 to 1071644672
Oct 30 06:57:45 nas-26-CB-3C kernel: BTRFS: device label 5e26cb3c:root devid 1 transid 752956 /dev/md0
Oct 30 06:57:45 nas-26-CB-3C kernel: BTRFS critical (device md0): corrupt node, bad key order: block=3660038144, root=1, slot=60
Oct 30 06:57:45 nas-26-CB-3C kernel: BTRFS error (device md0): open_ctree failed
Oct 30 06:57:45 nas-26-CB-3C kernel: EXT4-fs (md0): VFS: Can't find ext4 filesystem
Well, it does look like the root FS has failed, but it's not clear how to fix it if all the recommended solutions don't really work..
- mdgmOct 31, 2018Virtuoso
Running btrfsck on the data volume isn't advisable if you don't know what you're doing. You should always try to have a backup first before doing a btrfsck --repair.
The 4GB root volume on md0 could potentially be wiped, but that contains the log files. If there's a problem with the data volume then wiping the 4GB root volume would be wiping information that may be important.- tony2001Oct 31, 2018Aspirant
Ok, let me clarify it. Do you recommend to wipe md0 or do you mean that could have caused the issue?
I'd like to force OS reinstall, cause it looks like OS partition is broken, is there any way to do it except for the ones listed in my original post?
Resetting it to factory default would be an option, of course, but I would really like to avoid it.
- tony2001Nov 02, 2018Aspirant
Could you pls clarify what's the best way to exit Safe Mode and reinstall the OS?
