geodav1952's avatar
geodav1952
RNDU6000 Disk Upgrade
I have a ReadyNAS RND6000 using RaidAir 4.2.13 which up until recently comprised of 6 x 2 TB HDD.   It is configured using X-RAID2 with a single volume.    All has been working fine, however I recent...
  • StephenB's avatar
    Nov 09, 2019
    geodav1952 wrote:
    I have a ReadyNAS RND6000 using RaidAir 4.2.13 which up until recently comprised of 6 x 2 TB HDD.   It is configured using X-RAID2 with a single volume.    All has been working fine, however I recently replaced one of the HDD with a Western Digital WD40EFRX 4 TB ...  it only shows 1858 GB as being allocated which is the same as the other 5 x 2 GB HDD.   (ie per below)
    Do you mean Raidiator 4.2.31?  If you are still running 4.2.13, then you should update the firmware to 4.2.31 (which is the final firmware for OS 4.2).
    The capacity rule for single redundancy XRAID is "sum the disks and subtract the largest".  That means that you need to upgrade at least two drives to increase your space.  It's not possible to maintain RAID redundancy unless the two biggest drives are the same size.
    Also with OS 4.2, there are two limits to expansion that aren't well documented.
    1. A volume can't expand over 16 TiB.
    2. A volume can't expand more than 8 TiB from it's starting size.
    You aren't at the first limit, but it is possible that you are at the second.  If you initially installed one 2 TB drive, then your starting size would have been 2 TB, and your growth so far be 8 TB.  But if you initially installed all 6 drives, then your starting size is 10 TB - so only the first limit would apply to your system (because you'd reach it before you hit the second limit).
    If you initially installed 2x6TB (starting size 10 TB), then if you upgrade a second drive your volume will expand by 2 TB to 12 TB.  The NAS reports TiB, not TB, so it would show a ~10.9 TiB size.  You could upgrade two more disks (4x4TB+2x2TB) without reaching the 16 TiB ceiling.  If you tried to upgrade to 5x4TB+1x2TB, you'd exceed the 16 TiB ceiling, and the expansion would fail.
    When you do upgrade the second disk, the system will first resync the existing volume.  When that completes, the system will need to reboot before expands the volume.  Often that reboot needs to be done manually.  That reboot won't be needed when you upgrade a third disk or fourth disk.
    But if you initially installed 1x2TB (starting size 2 TB), you'd need to back up your data, do a factory reset with all drives in place, and then restore the data from backup in order to be able to expand to 4x4TB+2x2TB.
    A variant is to convert your NAS to OS 6 as part of the factory reset - it doesn't have either of the two expansion limits described above.
ProSupport for Business
