vdvb
Apr 12, 2017Aspirant
RNDX wont start
Product Model: ReadyNASRNDX4000
Purchase Date: Oct 27, 2011
After a power cutoff my nas wont start. i think psu dead.
where can i buy a cheap replacement unit to help me out for a few mo...
vdvb
so what 3rd party route?
what type/model do i have to look for?
the migration thing is going to be in a few months.
thx for the reply.
Bert
Apr 12, 2017Guru - Experienced User
If you google "RND4PSU1" you can find some compatible PSUs. They are often significantly more expensive than stock ATX supplies.
If you are comfortable with modifying the 20 pin cable pinout, then you can purchase a stock supply and adapt it. Sandshark is active here, and is a good resource - if he doesn't chime in, you can PM him using the messages link in the upper right of the forum page.
This thread might be helpful if you want to mod a stock supply: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Inexpensive-power-supply-replacement-for-legacy-4-bay-Readynases/td-p/1016241
