BrakinDeep
Dec 06, 2011Aspirant
RNP BE corrupt? Jedi help needed - Case# 17321469
I recently upgraded to 4.2.19 on my RNP BE little over 2 month or so ago. No issues were noticed. Shortly after the upgrade, I pulled my external backup drive off. This was off for 1 month (wasn't sup...
mdgm-ntgr
Dec 06, 2011NETGEAR Employee Retired
If you get a drive as an RMA replacement that isn't on the compatibility list then you should go and buy a drive from the compatibility list. I know it's not nice to have to go and buy another drive, but NetGear can't be expected to provide support when you encounter issues that may be due to a compatibility issue with the drive not on the compatibility list. Many don't want to use RMA disks in a primary storage system anyway as RMA disks are refurbished.
Your profile indicates you also have 2GB RAM installed. 3rd party RAM upgrades are not supported. See http://www.readynas.com/?page_id=83
Using 3rd party memory and a drive not from the compatibility list are two reasons NetGear may deny support.
I would suggest you open a tech support case (http://www.readynas.com/support) and see what they have to say. Please edit the thread title (i.e. subject of first post in thread) to include your case number.
