BrakinDeep
Dec 06, 2011Aspirant
RNP BE corrupt? Jedi help needed - Case# 17321469
I recently upgraded to 4.2.19 on my RNP BE little over 2 month or so ago. No issues were noticed. Shortly after the upgrade, I pulled my external backup drive off. This was off for 1 month (wasn't sup...
BrakinDeep
Dec 07, 2011Aspirant
mdgm wrote: So you can't see the NAS in RAIDar (http://www.readynas.com/downloads)?
I do not see it when booted into Tech Support mode. I booted it in normal mode and it comes up with IP. Note that it is booting with no LACP grouping but direct to router still. So completely by-passing GS-108T switch.
Going to try removing the assigned DHCP I have for the RNP. Not sure if that could be causing any problems as I see a fresh IP being assigned in router when booting into Tech mode, just the RNP isn't accepting it/keeping it.
