otechcomputing
Apr 12, 2017Aspirant
rsync + smb usage issue
Hello! Long time!
I have an RN422 on the (recently upgraded from T-180) most recent 6.7.0 firmware. And, ah yes, I am currently resyncing & degraded due to replacing a drive.
I backed up my old iPhone via rsync ages ago. I want to pull the data back to my Mac. So, I added the SMB attribute to it. Now:
the share shows up
the folders within the share show up
there are 16 kbytes used when I do a drag/drop (or du -csh).
I went to my Mac, ran an 'rsync rsync://IP' and got the folder name. Then, I ran an 'rsync -avP rsync://IP/folder /Volumes/destination_folder' and ..
all of my data is copying!
How come SMB shows empty - but rsync works?
Buggggggg time?
I was in the Beta testers group... if that matters.
If you access with SMB and drill down into the folders, can you see and copy individual files?
I'm wondering if this a file permissions issue.
- jak0lantashMentor
Sounds like file permission alright.
Btw, "100APPLE" is not a 16KB file, it's a folder.
- otechcomputingAspirantThe folder is owned by me with my primary group.
I never said it was a file -- I said 16kb used.- StephenBGuru - Experienced User
I never said it was a file -- I said 16kb used.Ok, let's step back. I get that the amount used seems to be wrongly reported.
But
- Are all the files there?
- Do they seem to be intact when you copy them?
- otechcomputingAspirantI support storage for a living and am a Linux guy.
The screen grabs are very telling. A recursive list via a SMB share shows no data.
This smells like a bug -- if I had run this test during beta, I'd have reported it.
That being said - I suggest you try it. Speculation is tough when you can't put your hands on it.
Set a share for rsync only.
Rsync some data.
Enable SMB.
Try to see your data via SMB.
You cannot ( at least, I couldn't)
Try via rsync and the data is still there.
I replaced disks this weekend and it won't auto-grow from 2 to 3 TB, so I had to delete my data.
I'll set this back up and do another test -- I can't imagine the results changing.- otechcomputingAspirant
Welp, after a data removal re-creation - the problem no longer persists.
Perhaps, fallout from beta firmware.
Sorry for the goose chase!
