Yorg
Jan 30, 2013Aspirant
Rsync and remote IP problem
Hi, I hope you guys can help. CONTEXT: I have a readynas 2120 Ultra 2 at home, and a Qnap at work. The Qnap is on our network at work, and in windows explorer where is shows the network it has t...
Yorg
Jan 31, 2013Aspirant
Yes, I'd like to use SSH, but thought I'd just get it working first.
Will try the push from Qnap, but in the meantime, what is the correct syntax for host, path if trying to pull from Frontview to the readynas? (I tried those options but I'm at a loss.)
And is there another way of testing an rsync connection between home and office - not using the NAS devices - to see if the connection over the internet is available at all?
As for terminal - I think that's beyond me.
And eton, do you mean the shared destination 'directory''? Not sure what the 'volume' is.
Cheers
Cheers
