UCB
Feb 22, 2017Aspirant
Rsync Attributes
Hello there, I have an Rsync job configured between two OS 6 devices, and I see the origin folder attributes are not transferred to the destination. Is there a way to reconfigure the job so as to...
FramerV
Feb 26, 2017NETGEAR Employee Retired
Hi UCB,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- UCBFeb 27, 2017AspirantMy apologies for the delayed response. I have tried dragging and dropping, but the permissions are not retained. I have also specified the File Access permissions similarly (on the two devices, which both have Windows Active Directory users). Thank you.
- StephenBFeb 27, 2017Guru - Experienced User
Permissions are retained for me (with rsync). I don't use AD though.
Have you checked both the source and destination with ssh? UIDs and GUIDs are matched in the source and destination systems?
- UCBMar 01, 2017Aspirant
Hello. I see there are differences. I've decided to work on the permissions first, and then look at the Rsync option again. Thank you.
