UCB
Feb 22, 2017Aspirant
Rsync Attributes
Hello there, I have an Rsync job configured between two OS 6 devices, and I see the origin folder attributes are not transferred to the destination. Is there a way to reconfigure the job so as to...
UCB
Feb 27, 2017Aspirant
My apologies for the delayed response. I have tried dragging and dropping, but the permissions are not retained. I have also specified the File Access permissions similarly (on the two devices, which both have Windows Active Directory users). Thank you.
Feb 27, 2017Guru - Experienced User
Permissions are retained for me (with rsync). I don't use AD though.
Have you checked both the source and destination with ssh? UIDs and GUIDs are matched in the source and destination systems?
- UCBMar 01, 2017Aspirant
Hello. I see there are differences. I've decided to work on the permissions first, and then look at the Rsync option again. Thank you.
