gjenkins87
Jun 08, 2017Aspirant
Rsync backup problem using dyndns hostname
I have two readyNAS drives, one at work and one at home, they have both been working fine but I wanted to put a larger drive in the one at home so I started again with setting up my backups. When...
Jun 08, 2017Guru - Experienced User
gjenkins87 wrote:
When I use the work IP address 86.140.XXX.XXX it works fine but when i use my "myworkname.dyndns.biz" it does not work.
When you ping myworkname.dyndns.biz from a PC at home, does it resolve to the same 86.140.x.x IP address?
- gjenkins87Jun 08, 2017Aspirant
Yes, I am able to connect to me router at work when I'm home by using the https://myhostname.dyndns.biz:xxxx
Where xxxx is the router remote management port.
- StephenBJun 08, 2017Guru - Experienced User
Not exactly the question I asked, but likely good enough.
if IPv6 is enabled on the NAS, try disabling it.
If you have ssh access on the NAS, then try nslookup xxxx.dyndns.biz and see if that finds the right IP address.
Hi,
Thanks for getting back to me.
II know it's not exactly what you suggested but the teamviewer session i setup has timed out and I think the PC at home has now gone to sleep so I can only tell you what I have already tried.
I will try disabling IPv6 and report back.
I have no experience with SSH but I will give that a go too and tell you know how I get on.
Thanks for your help so far.
- Mar 14, 2019Retired_Member
