gjenkins87
Jun 08, 2017Aspirant
Rsync backup problem using dyndns hostname
I have two readyNAS drives, one at work and one at home, they have both been working fine but I wanted to put a larger drive in the one at home so I started again with setting up my backups. When...
Jun 08, 2017Guru - Experienced User
gjenkins87 wrote:
When I use the work IP address 86.140.XXX.XXX it works fine but when i use my "myworkname.dyndns.biz" it does not work.
When you ping myworkname.dyndns.biz from a PC at home, does it resolve to the same 86.140.x.x IP address?
gjenkins87
Yes, I am able to connect to me router at work when I'm home by using the https://myhostname.dyndns.biz:xxxx
Where xxxx is the router remote management port.
- Mar 14, 2019Retired_Member
