Digital999
Sep 18, 2016Luminary
Rsync email when job does not start
We had a disk usage mistake -- most of the available data space was used by an errant application. Because of the low disk space circumstance it seems that Rsync 'canceled' scheduled backups -- m...
Digital999
Sep 21, 2016Luminary
Thanks for the confirmation of our hunch.
Now picture 53 different sites and several backup jobs per site each day. Checking logs is not a viable solution.
In most OS environments when a timer fires that is considered an action. If the timer fires off a job sequence and that job encounters a problem then an exception should be thrown by the job's environment-- again another action.
This is an area that should be improved. Please consider it for the next release.
JennC
Sep 22, 2016NETGEAR Employee Retired
Hello Digital999,
I guess you can also try suggestion this at idea exchange board Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
