gk2
Mar 23, 2021Aspirant
RSYNC ERROR 4
Héllo, ReadyNas 104 in version 6.10.4. I get rsync error: requested action not supported (code 4) at clientserver.c(1098) when I try to rsync from a netgear to an openwrt based NAS. If I ssh...
- Apr 01, 2021
The DNS name is a local resolution (I am using OpenWrt router)...
The error looks to be only shown when trying the job from GUI ReadNas, but the job also look to complete...
on the ReadyNas :
$ ps aux root 19061 27.8 0.9 17196 5012 ? RN 13:06 0:42 rsync -vP -8 --timeout=1800 --recursive --links --times --omit-dir-times --devices --specials --ignore-times --one-file-system --owner --group --no-acls --no-perms --port=873 /tmp/19024/EBOOKS [email protected]::share2/EBOOKS/
on the OpenWrt NAS client :
$ tail /var/log/rsyncd.log 2021/04/01 13:06:23 [23456] connect from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 13:06:23 [23456] rsync allowed access on module share2 from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 11:06:23 [23456] rsync to share2/EBOOKS/ from [email protected] (10.4.2.25) 2021/04/01 11:06:23 [23456] rsync: ACLs are not supported on this server 2021/04/01 11:06:23 [23456] rsync error: requested action not supported (code 4) at clientserver.c(1098) [Receiver=3.2.3] 2021/04/01 13:06:24 [23457] connect from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 13:06:24 [23457] rsync allowed access on module share2 from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 11:06:24 [23457] rsync to share2/EBOOKS/ from [email protected] (10.4.2.25) 2021/04/01 11:06:24 [23457] receiving file list 2021/04/01 11:38:42 [23457] sent 19978620 bytes received 12183841 bytes total size 26229514080
$ top 23458 23457 nobody R 13716 3% 42% /usr/bin/rsync --daemon --no-detach 23457 2053 nobody R 6116 1% 40% /usr/bin/rsync --daemon --no-detach
For reference :
https://forum.openwrt.org/t/solved-rsyncd-error-4/92026
Thanks all for your advices and help !
Mar 26, 2021Guru - Experienced User
gk2 wrote:
admin@GDISK:~$ rsync -vP -8 --timeout=1800 --recursive --links --times --omit-dir-times --devices --specials --modify-window=1 --one-file-system --owner --group --no-acls --no-perms --port=873 /GDATA01/DOCUMENTS/RECUP/FILMS [email protected]::share2/
With the default task, this error appear :rsync error: requested action not supported (code 4) at clientserver.c(1098)Any one could help on fix this ?
Are you logging in as root on the NAS? If not, try that first.
Also, by default the NAS will try to use rsync over ssh. So also try adding -rsh=rsh to your command line, and see if that helps.
gk2
Mar 31, 2021Aspirant
the SMB, and RSYNC-SSH works fine.
only the pure RSYNC gie me this error...
- StephenBMar 31, 2021Guru - Experienced User
Did you try adding -rsh=rsh to the command line? If you did, then what happened?
- gk2Mar 31, 2021Aspirant
StephenB wrote:
gk2 wrote:the SMB, and RSYNC-SSH works fine.
Yes...tried...
Works fine from command line, with or without:
-rsh=rsh
It's only with the ReadNas WEBUI that I get this error with rsync.
Same command line (catched from a ps aux) in terminal work
It is odd that the captured command line works, but the backup job doesn't.
But you really should be using rsync over ssh anyway, since ordinary rsync isn't encrypted, and you are sending it over the internet.
