gk2
Mar 23, 2021Aspirant
RSYNC ERROR 4
Héllo, ReadyNas 104 in version 6.10.4. I get rsync error: requested action not supported (code 4) at clientserver.c(1098) when I try to rsync from a netgear to an openwrt based NAS. If I ssh...
- Apr 01, 2021
The DNS name is a local resolution (I am using OpenWrt router)...
The error looks to be only shown when trying the job from GUI ReadNas, but the job also look to complete...
on the ReadyNas :
$ ps aux root 19061 27.8 0.9 17196 5012 ? RN 13:06 0:42 rsync -vP -8 --timeout=1800 --recursive --links --times --omit-dir-times --devices --specials --ignore-times --one-file-system --owner --group --no-acls --no-perms --port=873 /tmp/19024/EBOOKS [email protected]::share2/EBOOKS/
on the OpenWrt NAS client :
$ tail /var/log/rsyncd.log 2021/04/01 13:06:23 [23456] connect from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 13:06:23 [23456] rsync allowed access on module share2 from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 11:06:23 [23456] rsync to share2/EBOOKS/ from [email protected] (10.4.2.25) 2021/04/01 11:06:23 [23456] rsync: ACLs are not supported on this server 2021/04/01 11:06:23 [23456] rsync error: requested action not supported (code 4) at clientserver.c(1098) [Receiver=3.2.3] 2021/04/01 13:06:24 [23457] connect from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 13:06:24 [23457] rsync allowed access on module share2 from GDISK.lpm.nddc.gk2.net (10.4.2.25) 2021/04/01 11:06:24 [23457] rsync to share2/EBOOKS/ from [email protected] (10.4.2.25) 2021/04/01 11:06:24 [23457] receiving file list 2021/04/01 11:38:42 [23457] sent 19978620 bytes received 12183841 bytes total size 26229514080
$ top 23458 23457 nobody R 13716 3% 42% /usr/bin/rsync --daemon --no-detach 23457 2053 nobody R 6116 1% 40% /usr/bin/rsync --daemon --no-detach
For reference :
https://forum.openwrt.org/t/solved-rsyncd-error-4/92026
Thanks all for your advices and help !
Apr 01, 2021Guru - Experienced User
gk2 wrote:
Yes for the crypted ssh rsync transfer over Internet...
But this is a local rsync, which may not require encypherement !
This is a bit confusing, since ls421de.lpm.nddc.gk2.net is a DNS name with a public IP address.
You might want to try using your local IP address instead of the DNS name in the backup job, and see if that behaves differently.
gk2
Apr 01, 2021Aspirant
on the ReadyNas :
For reference :
