mpa-ken's avatar
mpa-ken
rsync fails to copy directory timestamp (solved)
[Posting in case others run into this problem.]   I'm replacing a Windows box with a ReadyNAS 2304 (not available in the Model selection list above). I have an rsyncd server set up on the Windows b...
  • mpa-ken's avatar
    mpa-ken
    Jun 03, 2021
    I use BackupPC 4 on my CentOS 7 box (Linux respin of RHEL 7) to back up my workstations. It comes with a custom build of Cygwin rsync and instructions on how to repackage it if you want to deploy with a different config file. You can find a packaged release in the cygwin-rsyncd project here: https://github.com/backuppc
    As an aside, BackupPC would make a good "app" to supply for a ReadyNAS. A turnkey BackupPC system would be pretty nice for non-technical small offices.
ProSupport for Business
