pointer2null
Mar 15, 2015Aspirant
rsync from linux to readynas (duo)
I've had a readynas duo sat in the cupboard for a few years and have decided to put it to use as a secondary backup device. The problem is I cannot seem to get rsync to connect. I've searched googl...
Mar 15, 2015Guru - Experienced User
The duo runs rsync version 3.0.9 protocol version 30 (at least the 4.1.14-T6 firmware does). So perhaps add --protocol=30. Perhaps also try w/o the -z.
is nastest.sh running rsync over ssh? (what is the port 22 error all about?)
- Aug 22, 2020Retired_Member
