pointer2null
Mar 15, 2015Aspirant
rsync from linux to readynas (duo)
I've had a readynas duo sat in the cupboard for a few years and have decided to put it to use as a secondary backup device. The problem is I cannot seem to get rsync to connect. I've searched googl...
Mar 15, 2015Guru - Experienced User
Can you run the backup from the duo?
- Aug 22, 2020Retired_Member
