pointer2null
Mar 15, 2015Aspirant
rsync from linux to readynas (duo)
I've had a readynas duo sat in the cupboard for a few years and have decided to put it to use as a secondary backup device. The problem is I cannot seem to get rsync to connect. I've searched googl...
pointer2null
possibly but it wouldn't be of any use. I use rdiff-backup which the duo doesn't support. so my plan is to use the rdiff-backup to produce the primary backup set and then simply rsync this to the readynas.
- Aug 22, 2020Retired_Member
