pointer2null
Mar 15, 2015Aspirant
rsync from linux to readynas (duo)
I've had a readynas duo sat in the cupboard for a few years and have decided to put it to use as a secondary backup device. The problem is I cannot seem to get rsync to connect. I've searched googl...
Mar 15, 2015Guru - Experienced User
Two thoughts - you could try using guest or nobody instead of root, and see if that avoids the password prompt.
Also, another way to get there would be to mount the NAS share on the ubuntu system with NFS.
- Aug 22, 2020Retired_Member
