pointer2null
Mar 15, 2015Aspirant
rsync from linux to readynas (duo)
I've had a readynas duo sat in the cupboard for a few years and have decided to put it to use as a secondary backup device. The problem is I cannot seem to get rsync to connect. I've searched googl...
pointer2null
Mar 16, 2015Aspirant
Will give the guest account a try.
A mounted NAs share will work so will probably go with that since rsync seems lacking.
Thanks.
Thanks.
- Aug 22, 2020Retired_Member
