stijnghesquiere
Dec 15, 2015Aspirant
Rsync not working with restricting security options in 6.4.1
After updating to Readynas OS 6.41 my rsync backups over SSH with KEY to another server do no longer work. The remote server has this option in /root/.ssh/authorized_keys command="/usr/local/bin/r...
JennC
Dec 22, 2015NETGEAR Employee Retired
Hello stijnghesquiere,
Welcome to the community!
I believe this is something you need to report to support center since it started after FW update.
There is one rsync topic that got resolved that you might want to read on: https://community.netgear.com/t5/Using-your-ReadyNAS/Backing-up-via-rsync-ssh-failing-since-upgrade-to-6-4-1/td-p/1013841/page/2
