raden10's avatar
raden10
Rsync over SSH - cannot connect to remote
Hello! I am trying to push data from a local ReadyNAS 202 to a remote ReadyNAS 102 accross the internet using a backup job initiated on the local 202. I get "Unable to connect to host - 7077010...
  • raden10's avatar
    Aug 23, 2016
    I finally got this working!!
    I had two problems with my setup:
    1) I was using the WAN IP of the ReadyNas - I should have been using the WAN of my Router! Doh....
    2) I had to put /data in front of my Remote Path - eg /data/Documents/
    As soon as I did both of these things everything works via the frontend. :)
    Hope this helps someone...
ProSupport for Business
