raden10
Aug 19, 2016Aspirant
Rsync over SSH - cannot connect to remote
Hello! I am trying to push data from a local ReadyNAS 202 to a remote ReadyNAS 102 accross the internet using a backup job initiated on the local 202. I get "Unable to connect to host - 7077010...
- Aug 23, 2016
I finally got this working!!
I had two problems with my setup:1) I was using the WAN IP of the ReadyNas - I should have been using the WAN of my Router! Doh....
2) I had to put /data in front of my Remote Path - eg /data/Documents/
As soon as I did both of these things everything works via the frontend. :)
Hope this helps someone...
raden10
Aug 23, 2016Aspirant
mdgm-ntgr
Aug 23, 2016NETGEAR Employee Retired
Great! You can now mark as the accepted solution your post that answered your own question!
