Bdko34u6cP9st7o
Jul 17, 2012Aspirant
Rsync over SSH on consumer-grade ReadyNAS
Hi all, Has anyone used the RSync over SSH Enabler (x86) http://readynasxtras.com/readynas-x86-add-ons/rsync-over-ssh-enabler-x86? I'm not at all put off by the cost (a buck), but I'd like to be c...
blumman
Jul 26, 2012Aspirant
ub1k wrote: Hi i have similar problem.
I try configure a yinter backup (open source project), but i can't set a ssh server on ReadyNAS Ultra 4 Plus, RAIDiator 4.2.19.
I have install Enable Root SSH Access (http://www.readynas.com/?p=4203) : Successfully enabled root SSH access.
Rsync is enabled in protocol on ReadyNas.
But when yinter server (on my PC) connect to ReadyNas a looking a msg:
Connecting to 192.168.1.100
Error retreving directories (code: 12)
Permission dened (publickey .password).
rsync: connection unexpectedly closed (0 bytes received so far) [Receiver]
rsync error: error in rsync protocol data stream (code 12) at /home/lapo/package/rsync-3.0.9-1/src/rsync-3.0.9/io.c(605) [Receiver=3.0.9]
Connection to 192.168.1.100 failed, attempting key upload
Key upload from 192.168.1.100 failed
Connectinf to 192.168.1.100
Error retrieving directories (cde 250)
What is wrong?
Sorry for my english.
Hi ub1k,
I have never tried rsync to a Windows machine so I don't know how that works. Are you trying to do rsync over SSH to your Windows machine? If that is the case you probably have to buy the Rsync over SSH plugin to get this option available. IF you are trying to do normal Rsync it should work and you probably have configured the backup incorrectly.
I know that there's a document linked in the forum somewhere that describes how to setup Rsync. This guide makes the destination server "pull" the backup from the source server. I have on the other hand configured my backup so that the source machine sends the backup to the destination machine. Make sure you have added the correct ssh-rsa key in the authorized_host file. I had mixed it up so the destination could SSH to the source but not the other way around which obviously made my backups fail.
