ArchPrime
Jan 20, 2020Guide
Rsync over SSH to Digital Ocean Droplet
Hi, when stting up a backup job I am struggling to get my Ultra6 to connect to my remote Digital Ocean Droplet , so it can download ald locally store backups from there. I have added the SSH publ...
ArchPrime
Jan 22, 2020Guide
Thanks Stephen
I set up 'ReadNAS' as a username on the Digital Ocean Server (I think) but may not have pulled this off correctly - certianly did not manage to connect to the server from the ReadyNAS device using this user name. (I should probably have picked a different name to avoid confusion!). Not all of the instructions for adding a new user account that I found online worked as described
I gave up on that and ended up adding the ReadyNAS device's ssh public key to the authorized_keys file on the Digital Ocean server for my root account - which at least now allows me to connect as as user 'root' from my ReadyNAS device, Even if I can get no further.
Yes, I am trying to initiate a connection from ReadyNAS device, in order to retrieve the contents of a folder on the Digital Ocean server and save a copy of these to ReadyNAS shared folder
*** EDIT ***
While I was typing this response, it seems the problem has somehow self corrected - I had set up backup interval to once per day, and it so happened that this backup just executed itself automatically, and succeeded! I have no idea why it failed when initiated manually before.
I wonder if being simultaneously logged in as root from my PC via PuTTY helped in some way, or issuing that check status command you suggested somehow shook something loose?:
sudo service ssh status
Either way, much appreciate your help!
Jan 22, 2020Guru - Experienced User
That is mysterious (not sure how it would resolve a quota error), but if it is working, then all is well. You should manually check the destination folder on the NAS, just to make sure everything is ok.
If you are doing incremental backups, you can combine this with custom snapshots on the destination share to give you some retention (ability to roll back to previous versions). There is a setting there to only make snapshots when there are changes.
Note there is also an option in the advanced settings that will delete files on the destination (readynas) when they are deleted in the source (digitalocean). I use that option for my own backups (together with the custom snapshots). Then the main share has the same contents as the source, with older files (deleted, renamed, etc) saved in the snapshots.
- ArchPrimeJan 22, 2020Guide
Tkanks Stephen - that makes sense.
For anyone else tryingto do the same thing, below is the process that eventually worked for me:
Enable SSH on ReadyNAS https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides
Use PuTTy to access Digital Ocean server and type
nano /root/.ssh/authorized_keys
in the editor, copy-paste in the public key used by ReadyNAS, appending this at the end of the /root/.ssh/authorized_keys file (be careful to not overwrite any keys already present).
In the ReadyNAS backup dialog settings, I used::
Name: Backup via Rsync over remote SSH (drop down selection)
Host: mydomain.com (or server IP address)
Port: 22
path: /var/discourse/shared/standalone/backups/default (the path to files I want backed up on host - change to suit your own situation)
Login: root(Noting that if you followed the instructions for setting up ReadyNAS for SSH access correctly, no SSH passphrase will be associated with its public/private SSH key pair. This is rather important, as the ReadyNAS backup dialog does not provide for a passphrase)
As noted, at first this process did not work fully for me - using the ‘Test’ button in the ReadyNAS backup dialog with these settings did result in successful connection, but then initiating a backup generated error ‘Disk quota exceeded (122)’
But then a couple of hours later, without further (obvious) intervention on my part, when the backup process initiated itself again on its auto designated hour, this time it just worked as it should.Possibly my previous efforts at achieving a connection and testing using different settings were having some residual effect that impeded things at thetime, or perhaps being simultaneously logged in to the server from my PC as root via PuTTY at the same time as root via FileZilla (both using the original/default SSH public key associated with root) and then trying to log in as root via ReadyNAS device backup utility (using ReadyNAS’s public key that I added to authorized_keys file for root) was problematic.
