onimod
Mar 13, 2012Aspirant
Rsync PC to ReadyNAS
I have been trying to follow the instructions here: http://analystdeveloper.com/blogs/gurkaneng/archive/2007/08/05/3493.aspx to pull my W7 "Users" sub-folder to my ReadyNAS but I haven't had much lu...
Mar 13, 2012Guru - Experienced User
Does it also fail when you run it?
onimod wrote: The screenshot isn't mine - it's from the blog in the original post that I have been using as a guide.
I've tried re-installing DeltaCopy just in case too.
I tried Host:"192.168.1.40", Path:"backup" in the path and the test connection still times out.
There are a couple of scenarios where test connection fails, but the backup works.
