bobo7581
Oct 20, 2012Aspirant
Rsync Replicate
Is it possible to set up two ReadyNAS's to rysnc over the internet using the replicate.readynas functionality. I can get backups to work over the LAN or across the internet, however I don't seem to...
mdgm-ntgr
Oct 24, 2012NETGEAR Employee Retired
bobo7581 wrote: Hi Herbio, thanks for you reply, what is the genie app store? is this a netgear marketplace or something?
Yes
bobo7581 wrote:
Also isn't the Duo V2 different to the N+ V2 which is what I have. I beleive i couldn't get 1.1.5 originally because of the architecture.
The Duo and NV+ v2 are the 2-bay and 4-bay ARM models respectively. Genie Apps for ARM should work on both.
bobo7581 wrote:
I currently have a trial license for replicate which I am using until i'm sure it will do the job i want then I will purchase the full one. So far it isn't. Do you know if using the full license and version 1.1.5 that you can run the backup in a only modified files kind of mode? So that is isn't doing a full back up every night?
The Genie App for Replicate is free apparently.
