cgreentx
Oct 06, 2006Guide
Rsync slow as heck for everyone else???
I'm running rsync with a unix box on the same gigabit switch and it is ridiculously slow. So severely slow that it copied 200ish MB in about 3 hours. That's pretty harsh. Any ideas? Chris Green
cgreentx
Oct 10, 2006Guide
I PM'd you the link to the new capture.
.120 FreeBSD Box
.124 Kubuntu Linux Box
I fired up a quick rsyncd on the linux box and set up the tcp dump on the FreeBSD box per your request. I then performed a sync of the same file across from the rsyncd on the linux box.
receiving file list ...
1 file to consider
CT4MGM.SF2
4174814 100% 12.56MB/s 0:00:00 (1, 100.0% of 1)
Number of files: 1
Number of files transferred: 1
Total file size: 4174814 bytes
Total transferred file size: 4174814 bytes
Literal data: 4174814 bytes
Matched data: 0 bytes
File list size: 29
File list generation time: 0.001 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 98
Total bytes received: 4175437
sent 98 bytes received 4175437 bytes 1670214.00 bytes/sec
total size is 4174814 speedup is 1.00
.120 FreeBSD Box
1 file to consider
CT4MGM.SF2
Number of files: 1
File list size: 29
