cgreentx
Oct 06, 2006Guide
Rsync slow as heck for everyone else???
I'm running rsync with a unix box on the same gigabit switch and it is ridiculously slow. So severely slow that it copied 200ish MB in about 3 hours. That's pretty harsh. Any ideas? Chris Green
Jar_Jar_Binks
Oct 11, 2006Aspirant
We got the 2nd capture between freebsd and linux server. Unfortunately the rsync procedure was different from 1st capture between freebsd and readynas.
The 1st capture rsync transfer data, but 2nd capture rsync transfer module list.
But I can see there was also 100ms delay in 1.120 side once or twice. So I think if freebsd and the linux server rsync transfer data, it will be slow as well as freebsd and readynas.
You can compare the captures by yourself to see if I am right.
And to compare, you have to make a same test for rsync to transfer data instead of module lists.
