Guido80
Nov 09, 2012Aspirant
S.M.A.R.T. disk errors since firmware update!
HELP! On November 5th I updated the firmware on my RND2000 (10/2010, see setup below) from v4.1.6 to v4.1.10. After the successful update my internal disk #2 suddenly starts turning out more and more...
Guido80
Nov 23, 2012Aspirant
StephenB wrote: What you need to do is replace the disk. The normal recommendation is to replace when the count reaches 50.
Thanks Stephen, I guess that's the only way out.
Now comes the task of choosing a replacement disk (or two). Could it be that certain disk models are affected by the power timer in my ReadyNas? For instance, would it be better if I keep it running 24/7 instead and enable spindown of the disks?
