twc
Jan 12, 2017Aspirant
sabnzbd causes high system load
Hi all, Is it normal that sabnzbd drives the sysload up to 143? (as reported in the top right corner of the web interface) I see three recently finished downloads (with "busy" spinners) in t...
- Jan 23, 2017
I think the NAS runs fine until sabnzbd begins repairing one of the downloads. So, I'll switch that function off (per the last post here). And then hopefully I'll be able to see which downloads need intervention, and run those repairs manually from my Mac.
However, now sabnzbd isn't able to start up. Are you able to take a look please?
Jan 12, 2017Guru - Experienced User
You probably should also post this in the sabnzbd forum.
twc
Will do thanks
- twcJan 13, 2017Aspirant
Does TOP give any clues?
Tasks: 413 total, 5 running, 408 sleeping, 0 stopped, 0 zombie %Cpu(s): 59.1 us, 28.5 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 12.3 si, 0.0 st KiB Mem: 508720 total, 391488 used, 117232 free, 428 buffers KiB Swap: 1047420 total, 326248 used, 721172 free. 21276 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2756 admin 20 0 644432 80764 3144 S 33.0 15.9 305:14.18 sabnzbd 2669 root 20 0 246188 10628 1284 S 32.7 2.1 1329:56 lite_mv 22335 admin 20 0 22164 17852 276 R 13.5 3.5 191:38.58 par2 404 root 20 0 0 0 0 S 10.7 0.0 92:22.97 kswapd0 1095 root 20 0 0 0 0 S 3.9 0.0 146:20.98 md127_raid5 13338 tony 20 0 5784 1768 1160 R 2.5 0.3 0:00.52 top 10203 root 20 0 0 0 0 S 1.9 0.0 0:18.38 kworker/u2:4 3 root 20 0 0 0 0 R 1.1 0.0 119:16.63 ksoftirqd/0 9821 root 20 0 0 0 0 S 0.8 0.0 0:19.37 kworker/u2:0 981 root 0 -20 0 0 0 S 0.3 0.0 15:20.16 kworker/0:1H 2376 root 20 0 23596 1308 1112 S 0.3 0.3 2:56.19 minidlnad 7837 root 39 19 10404 916 844 D 0.3 0.2 0:00.84 archive_mrg_mv 12502 root 20 0 0 0 0 S 0.3 0.0 0:02.41 kworker/u2:5 29327 root 39 19 10404 892 820 D 0.3 0.2 0:03.34 archive_mrg_mv 31729 root 39 19 10404 1032 960 D 0.3 0.2 0:02.94 archive_mrg_mv 1 root 20 0 26648 536 292 S 0.0 0.1 0:27.05 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.19 kthreadd 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 7 root 20 0 0 0 0 R 0.0 0.0 4:59.89 rcu_sched 8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh 9 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0 10 root rt 0 0 0 0 S 0.0 0.0 0:02.60 watchdog/0 11 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper 12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns 273 root 20 0 0 0 0 S 0.0 0.0 0:00.17 khungtaskd 274 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback 276 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto 277 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 biosetI've also noticed about 200 processes like this:
/apps/surveillance/bin/archive_mrg_mv autobackup
- FramerVJan 14, 2017NETGEAR Employee Retired
Hi twc,
Where you able to get in touch with sabnzbd if this is normal for their app? I could have you case be checked but I need to now if the app is working as it should be.
- twcJan 14, 2017Aspirant
Hi Framer, this is what we're up to over on the SAB forum:
Repairing takes a lot of CPU power. That is what you experience. ...
Your ReadyNAS 10400 is a low-spec machine, so you'll never get the same speed as on a
PC with an Intel Core CPU. ... Your sysload values are so insanely high and your top
output does not match that, that 1) something else must be going on (like disk IO problems)
or 2) there is a bug in your OS / Python / SABnzbd reportingAre you able to help diagnose?
Is he talking about par2? Is there a known issue with that perhaps, on the 10400?
