twc
Jan 12, 2017Aspirant
sabnzbd causes high system load
Hi all, Is it normal that sabnzbd drives the sysload up to 143? (as reported in the top right corner of the web interface) I see three recently finished downloads (with "busy" spinners) in t...
- Jan 23, 2017
I think the NAS runs fine until sabnzbd begins repairing one of the downloads. So, I'll switch that function off (per the last post here). And then hopefully I'll be able to see which downloads need intervention, and run those repairs manually from my Mac.
However, now sabnzbd isn't able to start up. Are you able to take a look please?
twc
Will do thanks
twc
Jan 13, 2017Aspirant
Does TOP give any clues?
Tasks: 413 total, 5 running, 408 sleeping, 0 stopped, 0 zombie
%Cpu(s): 59.1 us, 28.5 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 12.3 si, 0.0 st
KiB Mem: 508720 total, 391488 used, 117232 free, 428 buffers
KiB Swap: 1047420 total, 326248 used, 721172 free. 21276 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2756 admin 20 0 644432 80764 3144 S 33.0 15.9 305:14.18 sabnzbd
2669 root 20 0 246188 10628 1284 S 32.7 2.1 1329:56 lite_mv
22335 admin 20 0 22164 17852 276 R 13.5 3.5 191:38.58 par2
404 root 20 0 0 0 0 S 10.7 0.0 92:22.97 kswapd0
1095 root 20 0 0 0 0 S 3.9 0.0 146:20.98 md127_raid5
13338 tony 20 0 5784 1768 1160 R 2.5 0.3 0:00.52 top
10203 root 20 0 0 0 0 S 1.9 0.0 0:18.38 kworker/u2:4
3 root 20 0 0 0 0 R 1.1 0.0 119:16.63 ksoftirqd/0
9821 root 20 0 0 0 0 S 0.8 0.0 0:19.37 kworker/u2:0
981 root 0 -20 0 0 0 S 0.3 0.0 15:20.16 kworker/0:1H
2376 root 20 0 23596 1308 1112 S 0.3 0.3 2:56.19 minidlnad
7837 root 39 19 10404 916 844 D 0.3 0.2 0:00.84 archive_mrg_mv
12502 root 20 0 0 0 0 S 0.3 0.0 0:02.41 kworker/u2:5
29327 root 39 19 10404 892 820 D 0.3 0.2 0:03.34 archive_mrg_mv
31729 root 39 19 10404 1032 960 D 0.3 0.2 0:02.94 archive_mrg_mv
1 root 20 0 26648 536 292 S 0.0 0.1 0:27.05 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.19 kthreadd
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
7 root 20 0 0 0 0 R 0.0 0.0 4:59.89 rcu_sched
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
9 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
10 root rt 0 0 0 0 S 0.0 0.0 0:02.60 watchdog/0
11 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
273 root 20 0 0 0 0 S 0.0 0.0 0:00.17 khungtaskd
274 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
276 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
277 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset I've also noticed about 200 processes like this:
/apps/surveillance/bin/archive_mrg_mv autobackup
- FramerVJan 14, 2017NETGEAR Employee Retired
Hi twc,
Where you able to get in touch with sabnzbd if this is normal for their app? I could have you case be checked but I need to now if the app is working as it should be.
- twcJan 14, 2017Aspirant
Hi Framer, this is what we're up to over on the SAB forum:
Repairing takes a lot of CPU power. That is what you experience. ...
Your ReadyNAS 10400 is a low-spec machine, so you'll never get the same speed as on a
PC with an Intel Core CPU. ... Your sysload values are so insanely high and your top
output does not match that, that 1) something else must be going on (like disk IO problems)
or 2) there is a bug in your OS / Python / SABnzbd reportingAre you able to help diagnose?
Is he talking about par2? Is there a known issue with that perhaps, on the 10400?
- FramerVJan 15, 2017NETGEAR Employee Retired
Hi twc,
The support from SAB is actually trying to point out 3 possibilities I think.
1. The ReadyNAS is under powered and it taking most of its resources when a repair is happening.
2. An HDD failure.
3. A possible issue with our OS.
For the 2nd concern, we can check that via the system logs.
How do I send all logs to ReadyNAS Community moderators?
For the 3rd concern, updating to our latest firmware would be our way to go.
ReadyNAS OS 6 Software Version 6.6.1
Once we check these and see that everything is okay. We can say that the ReadyNAS is just that not powerful enough to handle the repair with ease.
